3 crank start fail, then runs.
Old Jun 3, 2012 | 10:30 PM
Mortorq's Avatar
Car: '88 IROC T5 Vert ‘13 Vette
Engine: 305 TBI
Axle/Gears: 3:08
'88 TBI LO3 T5 Vert Iroc
Hi Guys,
Recently began having a problem with starting. (bone stock except for Hooker Aerochamber cat-back)
Car will crank, almost start and idle, then die.
Repeat 2 or 3 times.
Waited 2 secs each attempt with a mostly non-responsive accelerator pedal.
Car would start after a few attempts and run normally once it did stay running.
Did notice a slight fuel smell occasionally, and also noticed the temp gauge is
pegged beyond hot, with car on, off, or indifferent. (not overheating)bad ground? Separate issue I'm sure.
I'm a carb guy, new to EFI. Leaky injectors, bad fuel pump and/or relay?
Possibly occurs more after sitting longer.
How to check fuel pressure?
Thanks, Scott
Prolly is not a word
bryan623
Mar 22, 2021 06:43 PM
Caspar
Jun 19, 2016 11:19 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Bryan F
Aug 18, 2015 02:28 PM
Winchester1094
Aug 18, 2015 10:23 AM
