surging idle? 350 vortec swap
Old Jun 4, 2012 | 08:25 AM
SLOWMARO355's Avatar
350 vortec swap
New crate motor from Gm,ecm,chip from hypertech,distributor,coil,plugs,wires,fuel pump,trans, idle air control,tps, oil pressure switches, coolant sensor,knock sensor.
Will fire right up and run but idle goes up and down like it wants to cut off. Once warm it does it a little slower. Has anyone had this problem?
Old Jun 4, 2012 | 05:15 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: surging idle? 350 vortec swap
Probably just needs a tune, this treat could lead you in the right direction https://www.thirdgen.org/forums/diy-...-5700-rpm.html
My engine still does it wery little for around 1 minute after a start up in cooler themperatures.
MustangBeater20
Oct 29, 2022 09:20 PM
Fast355
Dec 2, 2016 06:33 PM
jbd1969
Aug 17, 2015 07:06 PM
