Delco / Delphi fuel pumps
Old Jul 5, 2012 | 10:37 AM
Schurkey's Avatar
Anyone have a RELIABLE source for fuel pump capacity?
I'm finding it very difficult to locate trustworthy specs for the various part numbers of in-tank OEM-style fuel pumps.
My suspicion is that most any of the Delco / Delphi / Airtex / Carter fuel pumps have about the same capacity in terms of gallons per hour. The only functional difference is the output pressure capability.
Folks advise using the Delco EP241 "TPI" fuel pump on TBI applications; the 241 will certainly push higher pressure than a TBI pump...but I bet the gallons per hour is nearly the same as the TBI pump.
I understand that the actual pump section of the fuel pump assembly can be different among the various brands and part numbers, but I think this has more to do with manufacturer choice along with pressure requirements and less to do with output volume.
The specs I'm finding is that typical volume for a non-Walbro pump is about 20--25 gallons per hour.
HAS ANYONE TESTED THE DELIVERY VOLUME OF THE TBI PUMP versus THE 241 (or equivalent) TPI PUMP?
Old Jul 5, 2012 | 11:15 AM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: Delco / Delphi fuel pumps
Pump delivers volume not pressure. Stock tbi pump could not deliver enough fuel volume to run at 15 psi on my engine, whereas the tpi pump could at that pressure and higher pressure.
Old Jul 5, 2012 | 11:39 AM
Ronny's Avatar
I did a search a year ago due to my N20 install with 350 HP on the motor w/o N20 "on". I "read" somewhere on a vendor site GM Delco TPI pump delivers 24 gal/hour or 91 liters/hour. to convert to lbs of fuel gas weighs 6.15 lbs / gal
Old Jul 5, 2012 | 11:53 AM
Schurkey's Avatar
Not exactly true. The pump used in the TBI fuel pump assembly cannot generate higher pressure. Not a matter of a shortage of volume, it's a matter of pump design. You could trigger the pump with the engine OFF, and not get ~15 psi. Wouldn't surprise me to discover that the electric motor was weaker than the one used in the higher-pressure pumps.
The TPI fuel pump assembly uses a different kind of pump within the fuel pump assembly that is suitable for higher pressure.
Yeah, that's about what I found; but it would be nice to have a spec for the TBI pump as well as some of the other part numbers.
24 gph isn't much. It'd struggle to support 300 horsepower (if that!)
Old Jul 5, 2012 | 12:09 PM
Ronny's Avatar
104 #/hr supports 393 HP per RBobs calculator.
I believe he uses 80%DC for calc. Not sure on BSFC? Maybe .45
104 lbs /6.15 lbs = 16.9 gallons/hour of fuel needed at WOT.
granted I "read" 24 gal on a vendor site.
Old Jul 5, 2012 | 12:37 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
good info. guys. Shurkey corrected me. Thank you.
Old Jul 5, 2012 | 01:59 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
I belive that 24 GPH is wrong for the AcDelco #EP241.
Originally Posted by thomas1976
To convert lbs of fuel to GPH (US galon per hour) of fuel and vice versa:
GPH = LBS / 6
LBS = GPH x 6
(off course the 6.15 you use is ok, weight varies with themp.)
Wich gives us: 212 lbs / 6 = 35.3 GPH
If the TPI fuel pump would flow only 24 GPH, as you can see, that is way less then the 35.3 GPH that your set up is actually flowing.
Internet search shows 40 GPH, 65-75 psi shutoff, for the TPI fuel pump ACD#EP241.
Old Jul 5, 2012 | 02:09 PM
Ronny's Avatar
Then 40 gallons it is !
Old Jul 5, 2012 | 02:43 PM
Schurkey's Avatar
I don't know RBob or his calculator. Figures seem WAY off to me.
(Round figures) Assuming .5 lbs. of fuel per horsepower per hour delivered at the appropriate pressure:
300 horsepower / .5 lbs per hour requires 150 lbs of fuel.
150 lbs. of fuel at 6 pounds per gallon = 25 gallons per hour at whatever pressure the fuel system requires--~6 psi for a carb, ~12 for a typical TBI, 40--50--60 (or more) psi for port fuel injection.
Even with your figures of 0.45 bsfc and 6.15 pounds per gallon, I come up with 22 gallons per hour.
22--25 gph at 6 psi takes much less pump than 22--25 gph at 40 psi.
If a TPI pump supports more than about 320 REAL (not "butt dyno") horsepower, I'd be amazed.
Old Jul 5, 2012 | 02:54 PM
Schurkey's Avatar
Got a link to the 40 gph? Does the 241 really throw 65--70 psi maximum?
Old Jul 5, 2012 | 03:06 PM
Ronny's Avatar
My error.
The 104# was the output of each injector(2). 75 lbs injector size at 25 lbs FP puts out 104# of fuel per hour, Each injector firing at every other distributor reference pulse(TBI) supports 393 HP. So 208# of fuel is delivered in an hour from injectors.
400HP/.5 = 200 lbs fuel...... 200 lbs/6= 33 gal
TPI pump puts out 40 gal/hr. I found 3 references to TPI pump output today.
Is this now accurrate?
Old Jul 5, 2012 | 03:08 PM
Schurkey's Avatar
Excellent!
Can you provide links to your sources?
Old Jul 5, 2012 | 03:17 PM
Ronny's Avatar
One was an LSx Forum one was Thomas above and the third another forum I forget. Nothing credible just opinion.
Old Jul 5, 2012 | 04:32 PM
thomas1976's Avatar
Car: 91 Trans am
You need to search in the AcDelco parts distributor catalog.
65-70 psi shutoff means, the pressure at wich no more flow occours.
I had the gauge showing somewhere around 60 psi once, by setting the fuel pressure.
Old Jul 5, 2012 | 07:21 PM
one92rs's Avatar
Car: SOLD!!!!!
wow this is really good info. we need a fuel pump sticky and all this type info in it.
Old Jul 5, 2012 | 11:44 PM
Schurkey's Avatar
May I also suggest:
https://www.thirdgen.org/forums/tbi/...ml#post4905005
Old Jul 6, 2012 | 08:49 AM
Ronny's Avatar
I checked the AC Delco site and did not find specifics on output of the 241. I did countless searches and only found references to 40 gal but also to lesser flow#'s mentioned. Other aftermarket mfg's post #'s but I see nothing specific to ep241.
Old Jul 2, 2018 | 10:36 AM
Ronny's Avatar
Back from dead.... I am about to put it to test.
I have a forged 396 SB Chev block in car today.
But not yet running. Will fire it up in a couple weeks if we can get interior done. Then goes to muffler shop. Compression 11.0/1. Cam 234/242 .05 112 LSA. 1.75 Hooker headers 3.0 dual exhaust. Edel Vic SP. Ported Edel RPM heads(2007). Port fuel/1000cfm Edel 4 barrel TB with EBL/ECU. Weak link is 24 lb injectors which will be replaced. TPI pump.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
