Fuel Injectors wont fire..
Just finished up my clutch replacement, got everything bolted together but when i went to start the car, i notice no fuel is coming out of the injectors. If its not one thing its another i suppose -_- I checked the fuses, they are good. The fuel pump primes, it is brand new. The starter engages. The SECURITY light turns off as its supposed to. Put a test light on one side of each injector pigtail they both have 12v key on. My factory manual calls for something or other tool to test injector pulse, but i dont have one of those. Need a little help. What else should i test? Grounds? ECM is new. Injectors are newish, Fuel filter is new. No kinks in the line etc. Thinking its something electrical..
Re: Fuel Injectors wont fire..
Found this on another website:
Unhook the 4 pin harness from the back of the distributor.
Attach the clip of your test light to 12V Positive.
Turn on the Ignition.
Tap the purple/white wire on the 4 pin dist harness (IC Reference High) with the test light probe; it should create a test signal and fire the injectors.
I did all this and both injectors clicked, and sprayed a nice cone of fuel. I also OHM'ed the pickup/reluctor coil and it tested within range. Could the ignition module be bad? I just spent a ton of money on the clutch so instead of throwing parts at it and hoping it works, i want to fix it properly.
Had the module tested. It tested good, but i bought a new one anyway because it was in poor condition. Worked good for a little while, but the issues are back. Was able to get it started but it runs poorly and stalls now. Still with the occosional lack of injector spray
Car: 1985 Volvo turbodiesel
Engine: 1989 305 TPI in the Volvo
Transmission: 1990 700r4
Axle/Gears: 3.73 Dana 30
Unconnected ground wire? Make sure you have a good circuit to the block etc. Getting any codes?
New2Chevy
Oct 4, 2015 11:27 PM
Firechicken86
Aug 12, 2015 10:07 PM
