no crank/no start TBI 350
Old Feb 1, 2013 | 11:59 AM
Kaoticmethod's Avatar
Car: 1978 Chevrolet Malibu
Engine: TBI 350
Transmission: 200r4
Axle/Gears: 10 bolt with 3.42's
Hello all,
I have a 78 Malibu with a TBI 350 in it from the car's original owner. Swap was done years ago at AZ Speed and Marine. I believe the engine to be from a 87+ chevy truck (centerbolt heads).
Question is where to start with a no crank/no start issue.
Ive replaced the battery.The headlights, dash lights, and aftermarket gauges all work but when I crank it, I get nothing. No crank, no click, just nothing.
Previously, I could get the car to crank on its own from the column but after replacing the battery, it seems to be back to a no crank/no start condition.
I plan to get the test light out and check the starter when I get home to make sure its getting power. Should I invest in one of the cheapie multimeter to assist with this?
Would any of you be willing to share some knowledge on how to tackle the no crank/no start issue? I was all set to start checking for fuel/spark prior to the car reverting back to the no crank condition.
Thanks in advance.
Ken
Old Feb 1, 2013 | 03:20 PM
Schurkey's Avatar
Re: no crank/no start TBI 350
Do you have power to the S terminal of the solenoid when the key is turned to "crank"?
Power at S terminal = defective starter, locked-up engine, faulty ground connection.
No power to S terminal = defective battery, defective battery cables, defective ignition switch, defective or mis-adjusted neutral safety or clutch pedal switch, and/or defective wiring connecting these components.
Old Feb 2, 2013 | 09:22 AM
Engine: TBI 350
Transmission: 200r4
Perfect! Thank you schurkey. I will try to see if I have power at the s terminal and will report back.
Thanks again.
Ken
Old Feb 6, 2013 | 03:40 PM
Matt1821's Avatar
Car: 87 Trans Am
Engine: 350 carb'd
Axle/Gears: Stock
Where is the s terminal? I have the same problem
Old Feb 9, 2013 | 02:50 AM
Schurkey's Avatar
On the starter solenoid.
Old Feb 9, 2013 | 05:38 AM
ricklovin93's Avatar
Car: 1988 camaro base coupe
Engine: 305 LO3
Transmission: gm 700-r4
i had a problem like yours and it ended up being the ignition wire going to the starter inside the steering column.
92camaroJoe
Jul 29, 2023 07:57 PM
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
theshackle
Mar 5, 2017 06:37 PM
92camaroJoe
Aug 13, 2015 06:07 AM
