AC Delco EP 241 fuel pump - what is in the box?
Old Feb 20, 2013 | 10:28 PM
82tarecaro's Avatar
I am thinking of purchasing this pump, but as advertised, they only picture the pump, with no specifics about what comes with it to install it.
So, those of you who have installed this into a TBI car, did it have everything needed to complete the installation?
I would like to know ahead of time so I can purchase things like the strainer, and submersible fuel line if it does not come with it.
Old Feb 21, 2013 | 03:03 AM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Re: AC Delco EP 241 fuel pump - what is in the box?
On the Summit catalog it looks to be just the pump itself, you would have to take yours apart and put this pump on your pump module. Any thing else you want (strainer, etc.) would have to be purchased seperately.
Old Feb 21, 2013 | 04:53 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Strainer has to be purchased seperately. I installed this pump recently, and it came with the little rubber hose to eliminate the pulsator. But if I recall, it came with screw gear hose clamps which I don't like, so I bought some FI type clamps that have fewer sharp edges. Pump also comes with a new seal for the locking ring.
Old Feb 21, 2013 | 10:25 AM
Schurkey's Avatar
Comparison of 241 to the OEM TPI pump in my K1500.
https://www.thirdgen.org/forums/tbi/...ml#post4905005
In the box: Pump, short piece of hose, two crappy clamps, two rubber insulators, and a wire-harness repair kit.
As said previously: Does not include the fuel strainer, purchase separately. I also used NAPA-brand fuel injection hose clamps rather than the cheapies included with the pump.
The pump I got for my Lumina (not a 241) did not include the harness repair kit, I had to buy it separately, an extra ~$20
Old Feb 21, 2013 | 12:30 PM
82tarecaro's Avatar
Schurkey - I wonder if you had a larger fuel line on your pickup because it is a truck application? Does anyone know what size the F body fuel lines in the tank are?
I am wondering if I should just get the Walbro kit from Racetronix. It comes with pretty much everything you need for a few bucks more and it is a better pump.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
9192camaro
16
Feb 3, 2019 12:21 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
