MSD 6A on TBI
Old Feb 25, 2013 | 05:18 PM
irishhockey34's Avatar
Car: 92RS
Engine: LQ4
Transmission: 4L80E
MSD 6A on TBI
Anybody out there running a MSD box on their TBI setup. I am considering doing this as an upgrade for my mild 355 TBI and was wondering if anybody had good results? Or is it just not worth it? And where did you mount it?
Setup below
Old Feb 27, 2013 | 02:15 AM
Schurkey's Avatar
Re: MSD 6A on TBI
I threw a 6T onto the left inner fender of my '88 K1500 TBI 5.7L.
Had it laying on a shelf in the garage, figured I might as well make it "work for a living".
I have noticed absolutely zero performance gain, but at least the MSD 8876 wire harness makes it a super-easy addition to the TBI vehicles.
If you don't have misfire problems, the MSD is unlikely to make any improvement. If you do have misfire problems, you're typically better-off to FIX THE PROBLEM(s) than to use a spark-box as a crutch while you ignore the root cause of the misfire.
If you don't already own the spark-box, don't go buy one. The only verifiable benefit to a spark-box would be the built-in rev limiter (my 6T needs a separate rev-limiter, do as I say, not as I do.)
Old Feb 27, 2013 | 10:02 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: MSD 6A on TBI
I put on on my perfectly good running TPI engine in my Van. I noticed a smoother idle, sharper throttle response, and a noticeable amount of low-end torque gain. I was also able to tune lean cruise, well leaner without it misfiring.
Old Feb 28, 2013 | 10:26 AM
Schurkey's Avatar
Re: MSD 6A on TBI
Smoother idle? The idle of my K1500 couldn't GET any smoother. The TBI cams are so mild. Did you change cams or otherwise modify the engine? (aside from the MSD)
BRoss99
Aug 10, 2025 05:08 PM
junior419
Apr 7, 2025 11:35 AM
codeysabatini
Nov 10, 2015 04:07 PM
LittleFranks
Sep 17, 2015 12:22 PM
JPrevost
May 27, 2001 12:37 PM
