Question
Old Mar 1, 2013 | 12:50 PM
ricklovin93's Avatar
Car: 1988 camaro base coupe
Engine: 305 LO3
Transmission: gm 700-r4
Question
I snapped one of the tps bolts inside the throttle body, Im going to have to make a run to the junkyard to find a new tbi unit, my question is doe the throttle body have to be from a 1988 vehicle (so i can use all the same sensors and connectors)? and does it have to be from a 5.0? From what i have read the 5.0 and 5.7 throttle body are the same, just different injectors.
Old Mar 1, 2013 | 04:11 PM
Jono4820's Avatar
Car: 1991 RS
Engine: 350 TBI
Axle/Gears: 3.08 lt. slip
Re: Question
Yes, 305 350 TB are the same less the injectors. Make sure your replacement has a cruise control linkage if you have it.
Old Mar 1, 2013 | 08:14 PM
Schurkey's Avatar
Re: Question
Or just remove the remaining piece of the bolt. Can't be that difficult to drill it out.
Old Mar 2, 2013 | 08:55 AM
Engine: 305 LO3
Re: Question
already tried, but i fcuked it up
Old Mar 8, 2013 | 03:47 PM
goliath88's Avatar
Car: 88 firebird convertible
Engine: 305 tbi v8
Re: Question
im on one, no problems.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
