PLEASE help. I need advice on my 305/350tbi swap before I lose my mind.
Old Mar 9, 2013 | 01:20 AM
WhiteRabbit's Avatar
Im an amateur. I just bought back my first car (literally, i bought it when I was 15, Im 25 now) Its a 92 rs 25th Anniversary. The guy who bought it from me originally swapped out the 305tbi to a 350tbi. It it surging in idle while warming up (it stops when warm). Ive been told I need to replace the injectors for 61-65lb injectors, the esc, ecm, knock sensor, and maybe fuel pump....BUT Im getting 1000 different opinions and responses. If I could possibly get specific info from anyone who has gone through this, I would truly appreciate it...AND...specific part numbers would be also very much appreciated. Im just not sure where to start. My head is gonna explode.
Old Mar 9, 2013 | 07:46 AM
ex-x-fire's Avatar
Re: PLEASE help. I need advice on my 305/350tbi swap before I lose my mind.
Well, do you know if he changed the parts over too?
Before changing the fuel pump, test the pressure. It should be 9-13psi, if you think that there is 305 injectors on the 350, why not buy a tbi adjustable fuel pressure regulator to add pressure (1lbs at a time & drive).
Make sure the egr valve isn't opening at idle, it'll cause it to run rough at idle & surge.
Check carefully for vacuum leaks.
Old Mar 9, 2013 | 08:58 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Mainly you need the ANLU 350 TBI chip. You should also have the following: 65lb injectors, 350 ESC module, 350 Knock sensor. Then you should be all set.
Old Mar 10, 2013 | 02:21 PM
Ok thank you very much.
I will do that. Thank you!
Old Mar 10, 2013 | 11:32 PM
thizzlamich's Avatar
Car: 88 Chev Camaro
Engine: L05 V8 from 93 Caprice Interceptor
Transmission: 4l60 Auto
Axle/Gears: Stock ones limited slip i believe
Anlu chip, 1228746 ecm, su154 knock sensor, esc100 spark control module, and 65pph injectors (or 350 inj 61pph with an adj fpr)
What ive gathered from all reading and cross referencing part numbers, that is if the engine is post 87 otherwise you need dif esc and knock sensor
These are autozone part numbers as well so easy to get
xkingcodex
Feb 12, 2020 07:43 PM
E Rod
Aug 28, 2015 05:17 AM
Hello, Michael
Aug 20, 2015 03:19 PM
jharrison5
Aug 19, 2015 05:53 PM
transamgta1Khp
Aug 17, 2015 12:18 PM
