Holley TB injector issues
Old May 13, 2013 | 06:42 PM
86firebird350's Avatar
Car: 91 GTA
Axle/Gears: stock
Has anyone had any issues with the injectors leaking and squirting fuel out of the top? Ever since I had the injectors cleaned and flow tested, I can't get them to seal regardless of how I turn them or how much I press them in. It seems like the retaining plate isn't holding the injectors in place as when the fuel system pressurizes it bends the plate and the injectors lift up slightly. You can see this in the picture below. I also posted a couple pictures showing the orientation I have the injectors pointed. I'm not sure if this is an issue or not.
I honestly don't know what to do at this point. Previously, the injectors would bend the plate and lift up slightly but I had managed to get them to not leak. It's really frustrating me since this little issue is keeping me from breaking in the new engine and putting a good tune on it. Any help, advice, previous experience, etc. you guys can share regarding something like this would be much appreciated.
Attached Thumbnails Holley TB injector issues-downsize2.jpg   Holley TB injector issues-downsize.jpg   Holley TB injector issues-downsize3.jpg
Old May 14, 2013 | 10:26 AM
Ronny's Avatar
Re: Holley TB injector issues
I would call the Company that serviced them. I find it hard to believe holley would use that sort of retaining plate. I see now on their site they do use it so should be OK. I bet O rings pinched or rolled or wrong size.
Old May 14, 2013 | 08:18 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
thats what i run i have had no problems i even popped them out awhile back and still no problems. i think you got a bad o ring or something like Ronny said.
Old May 17, 2013 | 07:47 AM
Car: 91 GTA
Axle/Gears: stock
They don't appear to be pinched or rolled or anything. It seems like they just aren't being secured in the pod by the retaining plate.
Old May 17, 2013 | 11:09 AM
Engine: gone
Transmission: gone
Axle/Gears: gone
maybe the retainging plate is bent or something? i'd imagine you would have checked that already. seems very odd.
Old May 29, 2013 | 07:31 AM
Car: 91 GTA
Axle/Gears: stock
Well I replaced both the O-rings and the retaining plate and the leaking appears to have been fixed. Not sure which one of these was the true issue but my hunch is that is was the retaining plate. Now I just have to figure out how to tune this thing lol
Old May 30, 2013 | 11:56 AM
Engine: gone
Transmission: gone
Axle/Gears: gone
tuning...i just love tuning.....not! good luck
im running 350 tbi holley equipped with EBL aluminum heads mild cam..about to go extreme than that though
Frozer!!!
Jan 19, 2024 04:55 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Jae992
Aug 27, 2015 09:07 AM
Bryan F
Aug 18, 2015 02:28 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
