TBI injectors not firing on start up
Old May 24, 2013 | 10:45 AM
BowtieLife's Avatar
This is a 94 k1500 with a L05 and the injectors are not firing on start up. If I pour some gas into the tbi it will fire right up and run fine but there is something up with the the injectors not firing on start. Any suggestions or something that can help me trouble shoot the problem?
Old May 24, 2013 | 11:09 AM
Ronny's Avatar
Re: TBI injectors not firing on start up
I would check the fuses for the injectors. Could also be a failed fuel pump. Check fuse.
Old May 24, 2013 | 12:12 PM
BowtieLife's Avatar
no fuses blown and I have fuel pressure
Old May 24, 2013 | 12:26 PM
Ronny's Avatar
borrow a noid light at AZ to see if current to inj's.
Old May 24, 2013 | 12:39 PM
Schurkey's Avatar
First Guess: Distributor problem. ECM does not get the signal that the engine is cranking.
Could be defective wiring, or other problems.
92camaroJoe
Jul 29, 2023 07:57 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
