1992 5.0l TBI Fuel pump relay
Car: 1988 Camaro Base model
Engine: 305 LO3 5.0L V8 TBI
Axle/Gears: 10Bolt Rear, Not sure the gearing
Ok, I've searched and searched and I can't find my set up or an answer... I have a 92 camaro RS 305 tbi... Since I bought the car, it takes a good 5-7 seconds to start. I recently found out that it's most likely the fuel pump relay. So I know the fuel pump relay is located on the drivers side firewall,... But there's two other relays that look the same. Apparently one is the fuel pump and the other two are maf burn off or something. So how do I know which one is the fuel pump??
Car: check
Engine: check
Transmission: check
Re: 1992 5.0l TBI Fuel pump relay
The other two relays are for the electric fan and (I'm drawing a blank). No MAF on a TBI setup.
Look for the relay that has a short red pigtail exiting from the socket. That will be the fuel pump relay.
RBob.
RBob.
92camaroJoe
Aug 13, 2015 06:07 AM
