fuel injector connectors
Car: 1991 RS Camaro
Engine: 305 tbi
Axle/Gears: stock 10 bolt
I've got a 91 305 TBI rs. I just recently removed the fuel injectors to send them out to be cleaned, and flow tested. In the process of disconnecting the wire pigtails from the tops of the electrodes, I managed to easily snap the squeezy plastic tabs. They were apparently too brittle due to never having been removed before. My query is whether I am able to replace those plastic connectors with new pieces. Also, where can I find the necessary gaskets for the rest of the unit? Thanks for your time.B-)
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: fuel injector connectors
STANDARD MOTOR PRODUCTS Part # 1704 , sk29 or jy any tbi 220 truck or car
Car: 1991 RS Camaro
Engine: 305 tbi
Cool, thanks for the fast reply there. Is that for the connectors, or the gaskets?
Car: 1991 RS Camaro
Engine: 305 tbi
ok, so I found the gasket kit on summit with the p.n. supplied, but the other number "sk29r jy" I don't know where to search for that one?
Engine: Lb9
Transmission: M20
http://www.summitracing.com/parts/smp-sk29/overview/ typo I intended to put sk29 or jy.
Firechicken86
Aug 12, 2015 10:07 PM
