Fuel Injectors are just dripping
Old Jan 15, 2014 | 06:00 PM
haywardiii's Avatar
I am trying to help my sister by getting her car running safely. It is an 88 sport coupe with the 305 TBI. At this point it won't start, unless starter fluid is sprayed in the throttle body where it will fire and run for a few seconds. I watched the injectors while I had a friend crank the car and they drip in alternate sequence. My guess is that the fuel pump is bad, but I thought I would ask some experts here before I drop the muffler etc to get to the fuel pump. Any thoughts would help.
Old Jan 15, 2014 | 06:38 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Fuel Injectors are just dripping
Check the fuel pressure.
Old Jan 15, 2014 | 07:16 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
there's a fuel filter under the middle of the car that could be clogged but the problem i had was the rubber hose in the tank between the pump and sender ruptured.ethanal kills rubber parts on these cars.
Old Jan 16, 2014 | 01:23 PM
haywardiii's Avatar
Thanks for the tip on the fuel filter location. I thought it was in the tank with the pump. Pulled the filter and found tons of rust sediment in the fuel. Fuel smelled rotten as well. I am going to clean the entire fuel system starting at the tank. The things we do for family.
bryan623
Mar 22, 2021 06:43 PM
New2Chevy
Oct 4, 2015 11:27 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
