Overall best bang for your $$$$$
Car: 1989 RS Camaro
Transmission: TH700R
Axle/Gears: No posi YET!
Finally over shortage on cash and problem after problem the 89' is finally in the shop. So after talking with the mechanic I decided to replace the engine with a new remans 305. I was quoted at 3,200 after parts and labor (block was 1800) this is at 97$ an hour
. I decided why not 350, was my original Idea so I'm looking into these. I read a lot but I just cant understand the numbers and outputs these spec mean if that makes any sense.
Thanks,
Thomas
1st
http://high-performance-engines.com/...duct_Code=VC01
2nd
http://high-performance-engines.com/...duct_Code=HP31
3rd
http://high-performance-engines.com/...duct_Code=HP29
. I decided why not 350, was my original Idea so I'm looking into these. I read a lot but I just cant understand the numbers and outputs these spec mean if that makes any sense.Thanks,
Thomas
1st
2nd
3rd
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Overall best bang for your $$$$$
That's a crazy high labor rate, why don't you do the labor yourself ? A 350 tbi will not cost more maybe even less, you need larger injectors rockauto.com has them for around $100 and a new prom programed for a 350.
Car: 1989 RS Camaro
I figured I go there and have them sent to southbay to flow better. I was thinking just going with ebl or would I just be content with a prom.
Engine: Lb9
Transmission: M20
https://www.thirdgen.org/forums/engi...ml#post5710796
http://www.ebay.com/itm/Standard-T-Series-TJ7T-Fuel-Injector-/261390897793?pt=Motors_Car_Truck_Parts_Accessories&hash=item3cdc1c9281&vxp=mtr
Engine: Lb9
Transmission: M20
http://www.summitracing.com/parts/na...make/chevrolet
With ca emissions I'm not sure what the laws are. Anything much more than stock cam specs without live tuning or a ebl may not pass. The heads on this engine suck but it would give you good low end torque and its reasonably priced. Going to a vortec engine rwould require external egr feed and a rather expensive tbi to vortec intake. I guess it comes down to your budget and emissions guidelines.
Car: 1989 RS Camaro
UltRoadWarrior9
Apr 28, 2020 10:39 PM
