Holley Terminator EFI w/ 2001 fuel system
Old May 8, 2014 | 06:57 AM
RSD's Avatar
RSD
Car: 83 Z28
Engine: 355 SBC
Axle/Gears: 3.90
Anyone see a problem using a 2001 LS1 fuel tank and fuel pump setup to supply a Holley Terminator EFI in a 83 Z28? Any advice is appreciated.
Old May 17, 2014 | 07:07 PM
cc 82Z-28's Avatar
Car: 82 Z-28
Engine: Built 406ci
Transmission: 700R4 w/3000 stall
Axle/Gears: 3.73 Torsen Posi, Moser Axles
Re: Holley Terminator EFI w/ 2001 fuel system
I don't think it should be a problem since all you need is 43lbs of pressure and it will supply it. I am in the process of getting ready to switch my car over to the Terminator and I am using the stock fuel tank, sending unit assembly, Bosch in tank fuel pump for supplying the fuel for mine. As soon as I burn some more gas out of the car I will start on the change over.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
RedLeader289
May 28, 2019 01:47 PM
Royal_Z
Sep 30, 2015 08:45 PM
dusterbd
Sep 29, 2015 08:40 AM
