TBI injectors not firing
Old Sep 23, 2014 | 07:42 PM
smartone4765's Avatar
Car: '92 RS
Engine: Vortec 350 engine code L-31R
Transmission: 700-R4
Axle/Gears: stock rear (for now)
so my car seems to have a gremlin. All seems well, the car will crank, the fuel pump clicks on, the injectors have pressure (I have an aftermarket regulator with a gauge), the injectors work (I have applied power to them directly) but they do not fire when cranking. I was able to get the car to run by cranking while spraying brake cleaner into the intake. Once the engine fired and ran for a few seconds, the injectors started working again. unfortunately this seems to have been a one trick pony as when I tried the same cheat again I was unable to get the injectors to kick on.
Thoughts?
Its gotta be a wiring issue or a problem with the ECU right? there arent any relays for the TBI injectors are there?
Old Sep 23, 2014 | 10:12 PM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Re: TBI injectors not firing
'4765
Make sure that you're getting +12 volts at injectors during cranking. Also, ECM ignition circuit that provides ECM with 12 volts, at plug Pin A6 (pink-blk) has 12volts or higher during cranking and run.
Another common source of no fire is malfunctioning VATS system https://www.thirdgen.org/vats_passkey_system
//RF
Old Sep 25, 2014 | 02:12 AM
Schurkey's Avatar
Do you have spark?
No spark, no injector pulse = failed pickup coil and/or ignition module. Pickup coil problems are common.
92camaroJoe
Jul 29, 2023 07:57 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
