Just joined and have a quesiton.
My camaro has always, bought new, rev'd around 1000 rpm's when I push in the clutch coming to stop. Now it has gotten to where it rev's between 1500 and 2000 rpm's, if my tach is correct. But I do know it does rev higher by the sound of the engine.
Where can I find the IAC and TPS on my engine? What is the voltage range for the TPS? Also, how do I go about cleaning the IAC?
Thank you.
Thank you.
Thank you.
IAC and TPS are both on the left side of the TBI unit opposite of the throttle linkageOriginally Posted by forstral
Just joined and have a quesiton.My camaro has always, bought new, rev'd around 1000 rpm's when I push in the clutch coming to stop. Now it has gotten to where it rev's between 1500 and 2000 rpm's, if my tach is correct. But I do know it does rev higher by the sound of the engine.
Thank you.
cleaning IAC
https://www.thirdgen.org/forums/v6/1...ac-system.html
adjustment for tps and iac
https://www.thirdgen.org/tpimod2/
