Need help
Old May 31, 2015 | 05:04 PM
Grizzlyboy100's Avatar
Need help
I have an 89 rs with 305 tbi. Not getting any fuel or spark. I changed the icm ECM new cap and rotor and coil. It cranks but still won't start. It did fire over and run for a bit and died now nothing. Any thoughts?
Old Jun 1, 2015 | 01:42 AM
Schurkey's Avatar
Re: Need help
No fuel, no spark?
I'd be looking for a defective pickup coil. MAYBE a defective ignition module, but I'd start with the pickup coil.
The pickup coil develops the cranking signal the ECM uses to time ignition and injector pulses. No crank signal, no fuel, no spark. Therefore, the wiring between distributor and ECM could also be faulty.
