breather with one-way check valve
Car: 1992 Firebird
Engine: L03 305 TBI
Axle/Gears: 2.73 posi rear
I have an open air element, so I plugged the vacuum line, kept the pcv valve, and put a breather on the passenger side valve cover.
I realize I should be using a breather having a one-way check valve, so as to allow gases to exit at higher pressure, but not allow atmospheric air to enter.
Anyone have any recommendations for one?
Thanks in advance
Thanks in advance
Re: breather with one-way check valve
You'd be so much better-off to remove the hot-air air cleaner, reinstall the OEM air cleaner and then assure that the air cleaner has a source of cold (ambient) air via the OEM ductwork. In winter, you could re-connect the Thermac system to prevent throttle-body icing, and in summer let the engine pull in ambient air.
Open-element air cleaners were obsolete in the '60s. Popular, but obsolete.
greasegrenade
May 17, 2016 07:11 PM
