1982 new heads
Car: 1982 corvette
Transmission: auto
1982 new heads
Hi guys this is my first post but I have read this forum for years .I have a 1982 corvette cross-fire.i have ported the intake and I have a aftermarket cam.I would like to change the heads.they are factory 76cc. I would like to go to a camel double hump with 64 cc chambers.can the stock computer handle the change in the chambers cc.
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: 1982 new heads
I don't know much about crossfire corvettes but someone here might even though this is a camaro / firebird forum. But that being said I would imagine going from 76cc to 64cc would be a much bigger issue. I believe the motor stock had a 9:1 compression going form 76 to 64 would bring you closer to 10.3 with the same dimension gaskets. It may become knock prone at that point with the little cam
Car: 1982 corvette
Transmission: auto
Re: 1982 new heads
the heads have the same size ports as most 350 heads ,the intake had very small ports .they have been ported to match the head.If I get lower cc heads will that raise the compression ratio and cause a problem with the computer?
Re: 1982 new heads
Probably wont cause a problem with the computer but it will probably cause a problem with detention.
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: 1982 new heads
I have heard of 305 heads being used(58CC IIRC) but compression would be getting up there a little and could cause a detonation problem.I have been thinking some about replacing the stock 76 cc '624s on my CFI 350-runs strong with mild ported '624s,but I know at least one of them has a crack and they also like to warp,seeping compression between the middle cylinders.I have thought about reworked 305 heads,72 cc Dart "iron eagle",heavily modified 1990s LT1 heads,or working over a set of 1975 '882 heads I have handy
I know those are not a real fave around here,but they are heavy pre-'77 casting and very similar to the '624s,but with slightly more restrictive exhaust port than '624s-porting will fix that.
