Someone to burn a better chip for my car
I have an 89 RS was a 305 car. Swapped it to a 350 non roller motor. Added a small comps cam. Have gotten everything done that I could read on here. Other than someone trying to burn a chip. I will be attending Cruising the Coast in Biloxi/Gulfport Miss. this year. Will be traveling from Shreveport and thru Baton Rouge and New Orleans area. Does anyone know of anyone in the area that does this service?
Re: Someone to burn a better chip for my car
Contact member Tuned Performance. He can set you up with a chip. People doing it are few and far between. Best to do it by mail.
GD
GD
Car: 91 WS6 GTA
Engine: 5.3
Transmission: 4l60e
He does it--look at his website
Scott R Hansen
(775) 530-5892
Tuned Port Induction Programming Services
www.scotthansen.net
Scott R Hansen
(775) 530-5892
www.scotthansen.net
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
You might want to do a starter tune then datalog using tuner pro rt.
Something like this https://www.thirdgen.org/forums/engi...tbi-350-a.html
The mask I'd is $61
http://tunerpro.net/downloadApp.htm
https://m.facebook.com/story.php?sto...56&__tn__=%2As
Once you can datalog I can assist or brian at tbi chips .
The mask I'd is $61
Car: 88 Firebird Formula
Engine: LO5 5.7 TBI/Ebl Flash
Axle/Gears: 2.73 stock rear end
Or check out Rbobs EBL Flash. http://www.dynamicefi.com/EBL_Flash.php
Its seriously worth the investment.
