L98 SA Table for EBL
Old Jul 19, 2017 | 09:16 AM
Cartrax's Avatar
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
Told I should have an SA table in my BIN file that looks like a L98 SA table (similar aluminum heads), um where do I find the L98 table? Thanks.
Old Jul 19, 2017 | 09:33 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: L98 SA Table for EBL
On your PC, in your Dynamic EFI folder, there will be a listing of bins and which one's they represent. Find the L98 bin, open it in Tuner Pro, copy the SA Main Table data, close bin, open yours then paste into your SA Main Table. Smooth out your idle area so that it coincides with your SA Idle State timing, meaning if your Idle State is 22*, make sure the L98 Main Table is averaging that much wherever your idle is hovering on the graph via kpa and RPM...
- Rob
Old Jul 19, 2017 | 10:33 AM
Cartrax's Avatar
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
Much obliged...
