305 tbi running bad and getting worse
Old Aug 21, 2017 | 08:36 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
I replace the TPS, IAC, coolant temp sensor. It started with a mild stumble at under 2000 RPM's, and now it runs rough at start up, weak throttle response, and running rougher. I will not drive it till I find an answer, cause I'm afraid it will quit running all together. Any suggestions?
Old Aug 22, 2017 | 02:24 PM
Schurkey's Avatar
Re: 305 tbi running bad and getting worse
Plug in a scan tool, read the data stream. You'll likely have your answer in fifteen minutes.
Until you locate a scan tool, you can do a cranking compression test, a cylinder-balance test, and perhaps a cylinder leakdown test.
Old Sep 1, 2017 | 06:02 PM
I replaced the sensors I listed in my previous post, along with cap, rotor, and plugs. I could not pull codes. The tune up helped over all, but I still get a intermittent stumble between 1 and 2 thousand rpms. I'm at a loss.
Old Sep 1, 2017 | 11:46 PM
Schurkey's Avatar
I didn't suggest looking for "codes".
I said "read the data stream".
Oh, yeah. How about the other tests?
Old Sep 2, 2017 | 09:00 AM
W.E.G.'s Avatar
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
Vacuum leaks?
Old Sep 3, 2017 | 11:52 AM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
If the timing is correct, rupture in FPR diaphragm?
Old Sep 3, 2017 | 01:00 PM
brianlibby791's Avatar
Car: 1989 Trans Am GTA
Engine: 5.7L 350 TPI (Deleted Cats)
Axle/Gears: Original 3.27
Sounds like injectors seizing up. Did you pull the air cleaner off while it was running and take a look at them? Try looking up the ohms that they should be properly running at and test them to see what they come back as.
