need ecm and prom 91 G20 350TBI 4L80 trans
need to find ecm and prom for friends van. His ex mechanic stold his so all we have is vin number to try to buy the right ones! Any help would be greatly appreciated. steve larsen
Re: need ecm and prom 91 G20 350TBI 4L80 trans
Call the cops/sheriff. The ex-mechanic needs to be prosecuted...
...unless he can show a Mechanic's Lien arrangement.
Sounds like a Judge needs to hear all about this.
Car: check
Engine: check
Transmission: check
The ECM you require is the 16147060, that number is listed as the "Service Number" on the top of the ECM on the paper label. It will have two light brown connectors (same as the harness connectors).
Not sure which MEMCAL is required.
RBob.
RBob.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
This one might work
https://m.ebay.com/itm/16147060-BAAX...oAAOSw3RZaMpxS
Baal is from a 91 c and k with a 5.7 4l80 transmission
