Adding IAT to EBL ECM with HAM Board - Wiring?
Old Aug 25, 2019 | 06:07 PM
Cartrax's Avatar
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
Adding an IAT (Intake Air Temp) sensor to my '84 Crossfire Vette and need wiring info help. Getting told to add wires and pins to connector positions C-11 and C-12 but I already have wires and pins there. In fact the only spare connector openings I see are C-1 and C-24. Anyone add an IAT to a HAM board EBL ECM and know the solution? Let me know, thanks.
Old Aug 26, 2019 | 08:05 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Adding IAT to EBL ECM with HAM Board - Wiring?
Use black 21 as the IAT input to the ECM. Ground the other terminal on the IAT, no polarity.
RBob.
Old Aug 26, 2019 | 08:11 AM
Cartrax's Avatar
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
RBob.
Thank you. Don't know how you stay on top of these posts... Anyway, read a post by Ronny who said pin 14 on black connector could be used if currently unused. To me that's a preferred solution since it's already wired and pinned. Any comment on that?
Noted it's rated at 12 to 14 volts - an issue? C-21 is rated at 5 volts.
Old Aug 26, 2019 | 08:40 AM
Cartrax's Avatar
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
Going with 21 - will pull 14 pin and move to 21. Or maybe not - if that's an a/c solenoid = no. Was thinking it's an air pump solenoid which I deleted... duh.
Old Aug 26, 2019 | 09:45 AM
Cartrax's Avatar
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
More - found wire it's not the a/c so it's usable but I also have an EGR delete ( Pin 22) gray wire which is more accessible than #14 so I'll move 22 to 21 on the connector and use it. End of story - will post results in case anyone is following for similar mod...
Old Aug 27, 2019 | 09:34 AM
Cartrax's Avatar
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
Worked great and an EZ fix. IAT is talking to ECM...
marks88gta
Jul 12, 2011 05:31 PM
jagmanofsteel
Aug 21, 2009 07:55 PM
1982TA
Jun 25, 2005 05:58 PM
88TPI406GTA
Feb 15, 2005 11:44 PM
