191 Camaro RS throwing a code 53 which is over voltage and I think a pinpointed it at the fuel pump circuit please help how to fix it??? Ty in advance
I'd be looking at the alternator/regulator. What does a voltmeter across the output terminal and ground show? How about across the battery positive and negative?
In the end, follow the service manual procedure for diagnosis.
Quote:
Code 53 is a VATs error. Code 54 is fuel pump relay error. There isn't an over-voltage error on the TBI f-bodys.Originally Posted by PapaRoach3
191 Camaro RS throwing a code 53 which is over voltage and I think a pinpointed it at the fuel pump circuit please help how to fix it??? Ty in advance RBob.
A bit more detail on what happens when trying to start the car and let it run would help A LOT in determining possible causes for whatever it's doing that is not working for you
