Starting problem
Old Apr 15, 2022 | 12:47 PM
Ibretired2's Avatar
Starting problem
My '92 -5L-tbi starts fine when cold and again if only shut off for 10 minutes but after 10 or so starts then dies unless I continually pump the gas until it " clears its throat " then runs fine. Any suggestions?
Old Apr 16, 2022 | 03:34 AM
Schurkey's Avatar
Re: Starting problem
1. What is the fuel pressure just before/just as the vehicle stalls?
2. How old are the various tune-up parts--cap, rotor, plug wires, plugs, PCV, fuel filter, air filter? When was the initial timing checked? Timing advance? EGR?
3. Connect a scan tool, verify ALL the sensors and computer outputs. Especially coolant temp, TPS, and IAC. What are the fuel trim numbers showing just before/just as the vehicle stalls?
Ibretired2
Apr 11, 2022 05:22 PM
cosmonautpg
Aug 13, 2021 10:11 AM
GXP
Sep 25, 2014 07:23 PM
ineeedmorespeed
Jul 19, 2006 11:16 PM
