TBI floods
Old Nov 13, 2023 | 04:19 PM
hugh.g.rection's Avatar
TBI floods
Soooooo I’ve red some of the other posts regarding flooded TBI I’ve tried some remedies and nothing. So when it’s cold outside 8c or colder I can’t even get it to shudder I pull the plugs and #3,5,4 and 6 and soaked if I heat them with a torch to clean them off and put them back in hot its almost fire if I clean them with a brush nothing. I’ve tried pumping it 3 times holding to the floor to clear the flood and nothing I’ve pulled distributor and found TDC and replaced distributor thinking timing was maybe out as it is a new distributor TBI is completely rebuilt including fuel pressure regulator and new injectors new coil and fuel pump new ecm plugs and wires and every sensor except O2 sensor and thermostat. I don’t know where else to check or what I’m missing
Old Nov 14, 2023 | 02:42 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: TBI floods
I'd recommend new spark plugs, toss the current ones.
Is this fresh gas? Or left over from the Summer? If left over it is easily a gas problem. Summer gas doesn't want to burn in the cold winter months. Just last week I had to put some fresh gas in a car that was not wanting to start. Summer versus Winter fuel.
No need for the three pedal pumps, just hold the go-pedal down while cranking. That will invoke clear flood mode.
Pop the air cleaner off and observe the injectors/pod at key-on, engine-off. Any fuel? If so then time for TB gaskets. No fuel should appear at all unless cranking.
If you have a scan tool it is worthwhile looking at the engine coolant temperature sensor (CTS) value. The lower it is the more fuel gets dumped in during cranking.
RBob.
Old Nov 14, 2023 | 04:27 PM
Schurkey's Avatar
Re: TBI floods
Connect a scan tool, verify ALL the sensors and computer outputs. In particular, assure that the coolant temp sensor is reading correctly.
I have no idea what pumping the pedal is supposed to do on a fuel-injected vehicle.
WHICH "TDC"? TDC-Compression, or TDC-Exhaust/overlap? Makes a big difference.
Has it run since all these "new" parts were installed? If not, you've maybe got faulty "new" parts. In particular, why did you change ECM? Does it have the correct PROM?
bluegrassguitar
Feb 18, 2014 07:49 PM
Spike_Akers
Mar 23, 2012 01:44 AM
EvoTech1
Apr 10, 2006 01:14 AM
odddoylerules
May 1, 2005 02:24 PM
