Help with the B*llSH!t
Old Jan 30, 2002 | 12:13 AM
InDa12's's Avatar
help with the b*llSh!t
okay i put the hoses on the front of the tbi but the back is where i dont know what to do.
does anyone know where the vacuum hose connects to, that is on the center of the tbi unit.
also when i hook my map up it starts crappin out on me.
does the map sensor hookup to the egr valve?
what does the egr hookup to.
man this is getting on my nerves.
please help me on all these questions that boggle my mind!!!
thanx
Old Jan 30, 2002 | 01:10 AM
JPrevost's Avatar
Car: 91 Red Sled
On the back of the TB unit there is only one vacuum pipe that should go to your map sensor. The EGR and hvac (climate controls) come off the intake runner vacuum source. It's that little funky looking fitting that is on the number 8 cylinder intake runner. Don't hook up the MAP sensor to that or you'll get a constant vacuum. The power brakes go from the intake manifold on stock aplication or aftermarket you'll need to tap into that little runner source.
