rear end gears for my 89,350(TBI)
Old Jan 31, 2002 | 10:43 PM
InDa12's's Avatar
i have the 89 350(tbi) with the 2.73 rear end if thats what is in there. im guessing so because everyone has that.
well i wanna goto a bigger gear, 3.73 or a 4.11
i dont know what gears will fit in the rear end that is stock on my car.
please help me on this, my car urges for the jump off the line
3.73 would be nice if it can fit
but 4.11 would also except gas --then also posi would be needed!!!
thanx
Old Jan 31, 2002 | 10:55 PM
NJ SPEEDER's Avatar
any gear ratio can fit in the housing you have, the gears are all teh same physical size. it is the jus tnumber of teeth on the ring and pinion gears that is changed.
as far as teh effect on your gas mileage you mention, it will be changed very little on the highway. it is arouidn town that it will be effected, depending on how hard you like to leave lights.
check out this thread for some rpm estimates for different speeds.
https://www.thirdgen.org/techbb2/sho...threadid=80234
later
tim
Old Feb 1, 2002 | 10:49 AM
RyanSS's Avatar
If you over 3.23 gears, you will need a new differential, a series 3 carrier I think it is. I have 3.42 gears, and they are great. 3.73 is about the biggest I would go on a daily driver.
Old Feb 1, 2002 | 01:43 PM
Tas's Avatar
Tas
you don't "need" a new carrier per se. Aftermarket gear makers have big gears for both carriers.
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
mizz0313
Aug 12, 2015 06:45 AM
