350 injectors in a 305TBI
Car: 91 Red Sled
Any 350 injectors will swap onto the 305 TB, they're the same exact thing. Only difference is the actual injectors flow rates, nothing else. Call around to local junkyards or use ebay to find some injectors. Don't forget to make your fuel pressure regulator adjustable when you take the injector pod off to change the injectors. There is a link to a visual pdf file tech article on how to make the fuel pressure adjustable.
Eric-86sc
Aug 24, 2015 09:01 PM
