ECU/FP Fuse Blowout - FP/FP Wiring? Dead maro =\
Old Feb 16, 2002 | 05:24 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Well, the FP/ECU fuse in my '88 is blowing out. I'm figuring the pump is fried, but before I go dropping the axle and the tank to get to it I'm passing all my diagnostics info past you guys first.. I'm sure ya'll know how much I'm looking forward to dropping the tank...
FP Relay connected: Turn key on, fuse blows as soon as FP relay trips for prime.
FP Relay disconnected: Turn key on, fuse holds.
FP Relay disconnected: Attempt to start, fuse blows as soon as oil pressure builds enough to trip backup FP relay.
FP Relay connected: 0.0 ohms between ALDL terminal G and ground
FP Relay disconnected: ALDL terminal G open circuit
Anyone else smell the possibility of a simple short (heh.. simple.. yeh..), or are the electric in-tank pumps known show a short condition when blown? Death of the fuse was sudden and unexpected, no probs with the car in quite some time... I've gone through a half dozen fuses trying stuff... ugh.
If anyone has a helms diagnostic sheet for this, it would be most useful..
Old Feb 16, 2002 | 06:01 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Other than a short, the windings in the fuel pump could have fused together(insulation burned off). This would cause a short circuit and result int he fuse blowing. Only way to find out would be to mesure the resistence at the pump.
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
stalkier
Dec 6, 2015 11:25 PM
justin57
Aug 20, 2015 07:05 PM
