ESC modual
Car: 91 RS Convertible
Engine: 355
Axle/Gears: 2.73 peg leg
The ESC module is not in your distributor. I think that you're thinking of an ignition module. The ESC module is located on the driver's side firewall near your electric fan and fuel pump relays. It's flat and kind of trapezoidal shaped and has a 4-prong connector going to it. How do you know it is your ESC module? It could very well (and is most likely) your knock sensor. I would replace it first.
