ajustable fpr tuning Q
Old Feb 18, 2002 | 03:14 PM
BPA's Avatar
BPA
How do i go about setting up up the correct fp , I have a Lo5 350 and 350 injectors. And what is the correct pressure at idle and full throtal under load. thanks guys trying to do a major tune up on this car.any ifowill be a great help
Brian
Old Feb 18, 2002 | 03:33 PM
BPA's Avatar
BPA
42-50 psi is what i found but i dont know if this is just for the tpi cars , what is stock and what would be the best for performance?
Old Feb 19, 2002 | 01:38 AM
1MEAN92RS's Avatar
Car: '92 Rally Sport
Engine: LO3
Read the tech article on tuning air/fuel with your o2 sensor and a multimeter (or get winALDL). Stock fp is generally too little causing a lean condition that gets worse with more mods.
Old Feb 19, 2002 | 01:36 PM
BPA's Avatar
BPA
I read the artical about using the o2 senor to tune but my question is what fuel pressure is stock and what is for max performance. I have a fuel pressure guage avalible to use so i figure this would be a more affective way of tuning than off the o2 maybe im wrong but even if so i wouldnt mind knowing what stock pressure is suposed to be set at. Hopefully today i can borrow a mitchell manual.if anyone has an idea on this it would be greatly appreciated.
Old Feb 19, 2002 | 03:09 PM
1MEAN92RS's Avatar
Engine: LO3
There is no real "set" stock fuel pressure. It appears that GM was pretty random with this, but it is almost always lean. I'm not sure about the LO5, but the max fuel pressure setting on the LO3 is about 15-16 lbs with optimum being about 12-13 lbs if I remember correctly. Opening it up close to full shouldn't hurt anything I believe, as long as the injectors don't start dripping really bad. The ECM is still gonna control the injectors using o2 sensor data. It's just good to have that extra umph for when the pedal meets the floor
Lmancha96
Sep 25, 2015 08:11 PM
