Fan swithc ?
Old Mar 13, 2002 | 10:34 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Fan swithc ?
where in the passenger side head is the fan switch temp sensor (i dont know the official name)
Old Mar 13, 2002 | 11:20 PM
Joel Geerling's Avatar
Car: 91 Formula
Engine: 305 TBI
The fan switch has a "mushroom-style" connector. It's higher up than the knock sensor (which has a similar looking connector). I'm gonna go out on a limb here and guess that it was in the region between plugs #4 and #6, but that might not be exactly correct. It's not too hard to find tho, esp if you have headers
Old Mar 13, 2002 | 11:26 PM
My305camaro's Avatar
If I remember right it is just behind and below 6...kinda high up on the block
Old Mar 14, 2002 | 09:15 AM
TS b4c's Avatar
If you have a v8 it is between cly. 6 and 8. If you jack up your can and get under it look up above the starter you will see it on the head right below the heat shield for the exhaust manifold. Getting it out is a whole new trick, I haven’t figured this out yet. Mine was bad when I got the car last fall and I never had a heat problem until last weekend. So yesterday I spent several hours beating on things with no luck. I might just end up a putting in a switch.
Old Mar 14, 2002 | 10:50 PM
racereddy20's Avatar
I feel your pain I spent a good while looking for that crap. i saw it last night when I was under the car. I'm doing a header swap this coming week. I Found it and felt relieved, but then i kinda realized how hard its gonna be to take it off. BTW the headers are cool!
Old Mar 15, 2002 | 01:55 PM
ok i found it. it has no connetor on it at all and i am pretty sure i found the connector that is supposesed to be on it. only thing is that is was hanging by the y-pipe and the end is burned to a crisp. i have noticed that my fan is on right after i start my car and the engine is only like 100*. is this why? also if a mod could move this to the electronics forum. thanks
Old Mar 15, 2002 | 07:24 PM
Car: 91 Formula
Engine: 305 TBI
I know it's early in the year (tho maybe not in TX) one possible reason for the fan coming on b/f 2xx degrees would be having your A/C selected on your heater/A/C controls in the car...
You can buy a replacement connector from GM for like $15.
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
BrianI
Oct 3, 2015 12:57 PM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
