I cant find my coolant fan switch
Old Apr 19, 2002 | 04:15 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
"located on the passenger side head"
Can someone give me more details, Im such a retard
Old Apr 19, 2002 | 04:17 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Look from under the car, between #6 and #8 plugs
Old Apr 19, 2002 | 04:37 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
here's someone's pic from underneath the car
Old Apr 19, 2002 | 04:41 PM
Car: 1988 IROC-Z
Engine: 427 SBC
Thanks guys!!
I found it, grounded it, and my fans didnt turn on
I dunno what else to do.
I ran 12V to both of my fans and they turned on. I replaced the relay too. And neither fan will turn on @220 or when the AC is turned on
Old Apr 21, 2002 | 01:23 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
You need to find the power feed to the fans, seems like you don't have 12v there...should be up near the battery, maybe a 30amp fuse or a fusable link...don't recall.
Old Apr 21, 2002 | 04:18 PM
rezinn's Avatar
You don't ground the sensor itself, you ground the wire going to it. Is that what you did? Did you replace the relay behind your battery? Have you replaced the sensor in your drivers side head?(might be reading wrong temp)
Old Apr 21, 2002 | 04:47 PM
Car: 1988 IROC-Z
Engine: 427 SBC
Yes I grounded the wire
Would replacing the sensor in the drivers side head have anything to do with the fans not turning on with the Ac?
I also replaced that relay too.
Old Apr 21, 2002 | 05:03 PM
Car: 1988 IROC-Z
have you tried grounding the green wire on one of the fan relays? that should turn the fan on.
Old Apr 21, 2002 | 06:01 PM
Car: 1988 IROC-Z
Engine: 427 SBC
Nope, I'll try that tomorrow.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
RazorN8
Jan 7, 2022 11:44 AM
TA8487
Aug 16, 2015 12:21 PM
Wylecoyote08
Aug 14, 2015 08:28 AM
