Serpentine Setup on L98 Aluminum Heads
Old Apr 20, 2002 | 06:45 PM
david auster's Avatar
Car: 1992 Camaro
Engine: 350 miniram
What I would like to know is if I have to drill and tap a hole in the passenger side head in order to switch to the serpentine belt setup. I think the brackets for the serp. setup use 3 bolts that attach to the head. One head has all 3 hole drilled and tapped and the other has only 2 dirlled and tapped. My motor is at the engine shop right now, so I am wondering if I should have him do the 3rd hole on the head.
Old Apr 20, 2002 | 08:37 PM
Blackened's Avatar
If it's not too big of a trouble... drill and tap the hole. It not, holding the bracket on by 2 bolts it really no big deal. It will work either way.
Old Apr 21, 2002 | 12:26 AM
Guest
Guest
Posts: n/a
Drill+tap the hole. Theres plenty of material to do it.
Old Apr 21, 2002 | 06:11 AM
Car: 1992 Camaro
Engine: 350 miniram
Thanks guys, I am having them add that extra hole. I am surprised that the hole doesn't come drilled and tapped from the factory. I guess the corvette serptentine setup uses a different bracket setup that only uses 2 bolts.
evilstuie
Jan 9, 2020 08:29 PM
midge54
Dec 27, 2019 04:14 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
jahblah
Aug 12, 2015 05:54 PM
L98GTA87
Aug 11, 2015 06:55 PM
