air tubes on my cats cracked off!
Old Apr 22, 2002 | 05:12 PM
e-man's Avatar
Car: 89 formula
Engine: 383
1-Will the cats burn out if the air tubes are not connected? 2-How bad will the emissions raise? 3-What about if I reroute the air line that was going to the cats to tie in with the air going in to the headers will lower emissions?
Old Apr 22, 2002 | 05:40 PM
rezinn's Avatar
Not if the car is running properly. Emissions will raise, but probably not enough to fail a check. That won't work, the diverter valve only sends air to the headers when the car is cold. Why can't you just fix it?
Old Apr 22, 2002 | 05:53 PM
e-man's Avatar
Car: 89 formula
Engine: 383
One cat I welded the tube back on the other I cant fix because I burnt a hole through the tube.(Im not the greatest welder!)
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
chazman
Aug 22, 2015 02:01 PM
drathaar907
Aug 6, 2015 04:20 PM
