What brands of Radiator Fans Will fit in front of 3rd Gen radiators
Old Apr 23, 2002 | 08:31 PM
CAMARO82's Avatar
What brand(s) of electric Radiator Fan(s) can fit in front of our radiator to push are through to cool. Thanks Greg
Old Apr 23, 2002 | 08:32 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I'm sure any, just make sure the diameter size won't be too big. A 10" should fit fine, but I doubt would flow enough.
Old Apr 23, 2002 | 08:33 PM
idrag2's Avatar
Hayden makes a thin line fan that will fit in front with ease......I think the biggest you can go is like a 10 or a 12 inch.....just my $0.02
Old Apr 23, 2002 | 08:34 PM
CAMARO82's Avatar
Do you think a 14" will fit?
Old Apr 23, 2002 | 08:38 PM
idrag2's Avatar
I doubt it......but you can always modify your hood latch brace to make it fit.........I had to trim mine up alot to get my tranny cooler in there.
Old Apr 23, 2002 | 08:39 PM
Guest
Guest
Posts: n/a
You can fit a 14" or a 12" up there without taking out the crossbars. If you remove the crossbars, you can fit a 14" and a 12" in the opening, but 2 14's wont fit.
In case you were wondering... the ones I have are Derale. I'm sure a Hayden would work as well, they are pretty similar.
Old Apr 23, 2002 | 08:43 PM
CAMARO82's Avatar
Madmax where did you get your fans from?
Old Apr 24, 2002 | 06:12 AM
Guest
Guest
Posts: n/a
Hmmm.
I got one of them from PAW in Chatsworth, CA. I think they have a website, I think its www.pawinc.com The other, I am not sure if I bought it from them or not. I dont see why a Hayden or other brand wouldnt fit. The 14 is close, but it fits.
Old Apr 24, 2002 | 07:13 AM
Blackened's Avatar
I have ONE 14 inch Hayden in front of the AC condensor. The crossbars keep it pressed against the condensor so all I had to was slide it in and forget about it. LOL It works really well for the A/C.
Old Apr 24, 2002 | 11:12 AM
gruveb's Avatar
Car: 1989 IROC-1
Madmax,
What about fitting 2 12" fans or a 10 and a 12 or maybe even a 10 and a 14?
What do you think?
Old Apr 24, 2002 | 10:03 PM
CAMARO82's Avatar
so a 14" will fit for sure???? Cause i need to know before I buy
Old Apr 24, 2002 | 10:04 PM
CAMARO82's Avatar
and does it really help cool alot?
Old Apr 24, 2002 | 10:24 PM
Guest
Guest
Posts: n/a
Does it fit for sure? Well, I can go take a picture of it if you'd like.
I cant see any reason you couldnt fit a 14 and a 10, 12 and 12, 10 and 10, anything smaller. 2 12's or a 14 and a 10 might be small enough that you could leave the crossbars in, but I am not sure.
With my stock 16 or 17 or whatever it is, the 14, and the 12 you can feel a nice rush of air behind the car when the fans are on It doesnt get hot, ever.
Old Apr 24, 2002 | 11:20 PM
CAMARO82's Avatar
Ok cool maybe that will help me out... did it get hott before you put the fan?
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
Reddeath210
Oct 6, 2015 08:20 AM
89lsc
Aug 14, 2015 04:58 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
