changed sensors
Old Apr 25, 2002 | 06:12 PM
hwcoll95's Avatar
Car: 1989 Iroc rebuild
Engine: 355 carb'd
Transmission: 5spd
Axle/Gears: 3:08 pos for a while
changed sensors
now temperature gauge don't work???HELP!!
Old Apr 26, 2002 | 11:41 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Might get some help if you tell us what sensors you changed
Sender for the temp gause is located in driver sdie head between #1 and #3 plugs, you should be able to see it from the top of the engine.
Old Apr 27, 2002 | 01:23 PM
hwcoll95's Avatar
Engine: 355 carb'd
Transmission: 5spd
thanx all
didn't change the one on driver side,since gauge worked fine before the work to get the fan/fans running,only touched the temp gauge wire when changing the plugs,will test more today
9192camaro
16
Feb 3, 2019 12:21 AM
Logan Bryant
Aug 27, 2015 11:52 AM
beast94
Aug 20, 2015 06:44 AM
92camaroJoe
Aug 13, 2015 06:07 AM
