Temperature gauge connector
Old Apr 28, 2002 | 04:08 PM
hwcoll95's Avatar
Car: 1989 Iroc rebuild
Engine: 355 carb'd
Transmission: 5spd
Axle/Gears: 3:08 pos for a while
in trying to get my fans to come on ,i went ahead and changed the plugs,now the gauge is from the sensor in the driver side head,didn't change it,took the connector off and cleaned,it doesnot fit snug,seems loose,is this why my gauge quit after i changed the plugs,chaged CTS front intake,and the one btween rear plugs passenger side,with no gauge can't determine if fans are fixed,other than i turn on AC and both run,did i change the wrong pieces??is it in the relay?? and need HELP with gauge,don't want to chage parts again since it worked fine before the work??
TrevinE
Sep 14, 2015 03:20 PM
86IROC112
Sep 11, 2015 04:04 PM
Ironhead38
Sep 7, 2015 02:26 PM
Chevy86 IROC-Z
Sep 7, 2015 01:13 AM
middian
Sep 5, 2015 01:42 AM
