Distributor trouble
Old Apr 29, 2002 | 08:52 PM
85transam1's Avatar
Distributor trouble
I remove the intake to replace the leaking gaskets and no matter how much I tighten the distributor hold down bracket the distributor still turns. Any suggestions on how to fix the problem?
Old Apr 29, 2002 | 10:19 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
You sure you're using the same bolt? Maybe you grabbed a longer one and it's bottomed out in the hole?
Old Apr 30, 2002 | 10:13 AM
Vader's Avatar
Make certain the gasket is in place at the base of the distributor and that the clamp isn't distorted or cracked.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
mrbird
Oct 20, 2015 03:43 AM
Damon
Sep 26, 2015 04:29 PM
Lmancha96
Sep 25, 2015 08:11 PM
