rear end uneven...
Old Apr 30, 2002 | 10:34 PM
ChevyGuy87's Avatar
Car: 2004 Wrangler Rubicon
Engine: 4.0
Transmission: NV3550
Axle/Gears: Dana 44s with 4.10 and air lockers
rear end uneven...
recently i noticed that my rear end isn't level. it sorta leans a little bit to the pass. side. i looked at the clearance between the lip of the fender and the tires, and on the pass side there's about 1.5 inches but about 3-4 on the drivers side. having a lopsided car is sorta buggin me. any ideas?
Old Apr 30, 2002 | 11:21 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Have you owned it since new? Has it been smacked? Look the rest of the car over for any signs of damage from an accident. Car has prolly been smacked. If that checks out OK, you can try getting some new (or different) springs as the old ones may be worn out and sagging at different rates. Adjustable spring kits are also available.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
BlackBoulder
Aug 11, 2015 11:15 PM
