Vortec intake gasket question. The part number for the gasket I got is 12529177 and
Old May 3, 2002 | 11:30 AM
bhaas's Avatar
The part # I referred to was the instructions part #. Sorry. Realized that about 5 minutes after I posted and could edit it out of the subject. I have the right part number gasket. 12529094.
My Performer RPM intake doesn't have water openings for the heads back by the distributor like all other intakes. Do I need to do anything special with this intake? Also, with this plastic odd *** looking Vortec gasket, do I need to use silicone sealer around the water jackets like always or will these seal? Thanks.
Brad...
Old May 7, 2002 | 11:08 PM
5.0killer's Avatar
bhaas
With the vortec gaskets you should use a little sealant around the water ports on both ends of them.
You will also need to run s water by pass from the manifold to the water pump. Edelbrock says they have a bypass kit that is provided with thier manifolds. I used hardware store fittings and a pice of copper tubing on mine, it seems to be working fine.
Old May 8, 2002 | 09:53 AM
bhaas's Avatar
Why do I need to run a bypass? Where do I run it to? I've been driving it for a couple of days now with no probs. That motor is sweet. Them Vortecs kick a5$. I called the dealer and asked a mechanic and he told me not to use any sealant so I didn't. I wanted to real bad though, but I risked it. No leaks anywhere. Those gaskets looked pretty cheesy to me, but I guess they work.
I bought the Edelbrock Vortec intake and I didn't get any bypass kit.
Thanks.
Brad...
Old May 9, 2002 | 01:22 PM
5.0killer's Avatar
Hey bhaas
My engine is a '96 so I needed the bypass I guess yours doesn't.
My intake is #2116 for carb. I put an adapter for tbi. It works great. Vortec heads are kick***.
1992 Trans Am
May 10, 2023 07:19 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
articwhiteZ
Aftermarket Vendor Review
Aug 18, 2015 07:26 AM
TA8487
Aug 16, 2015 12:21 PM
armybyrd
Aug 10, 2015 09:23 PM
