Where does that go!!
Old May 5, 2002 | 09:24 PM
SlowStangEater's Avatar
Ok Vader told me to check the other wires on my starter besides the positive battery cable. I know that there are 2 more on the b post on the starter and 1 on the S post......I think its an S post..... But where do all those wire lead FROM???? I think the one is a ground (isnt it?) Anyone have a diagram of where those wires go on an 89 Camaro? I think my starting problem is somewhere between the Starter and the Ignition Coil.
Old May 5, 2002 | 09:58 PM
Does anybody know?
Old May 5, 2002 | 10:26 PM
Ok guys I know someone in here knows the answer........Mark???
Old May 5, 2002 | 10:29 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Sorry don't know that one, believe me if I knew the answer I would have answered it by now, just wish I knew more about cars to help people like Vader does.
Old May 5, 2002 | 10:32 PM
I just figured that you would know..............Seems like you answer all my questions Vader said that it was most likely the 2 other wires on my starter that are causing it not to start when they get hot..........My father thinks that wires are getting hot and expanding.........then touching metal and shorting out until they cool down and back off. I dont know for sure though..
Oh by the way I bought my battery and of course kept the receipt!!!
Old May 5, 2002 | 11:40 PM
RJR99SS's Avatar
well one is the ground, the other comes from the ignition switch; which is in the dash i'm pretty sure. cant give you anything more detailed than that.
Old May 5, 2002 | 11:44 PM
Well were getting closer Does the other one go to the Ignition Coil??
