Factory Guage lights dont' work after popping fuse...even with new fuse.
Old May 6, 2002 | 01:54 AM
ChrisFormula355's Avatar
Car: Junk
Engine: Junk with nitrous
Transmission: Junk with gears
Accidently wired something up wrong while installing aftermarket guages and I fried something under the dash I think because even though it blew a fuse for the guage lights..........I replaced the fuse and the guages still don't work. Any ideas? What else shoudl I check if its not the fuse?
Old May 6, 2002 | 05:48 AM
ronterry's Avatar
Car: '94 Corvette
Have you check the gauge bulbs ? You may have fried them.
Also double check that it's the right fuse you changed. Check to make sure all your fuses are OK. Drop in another fuse in case that one is bad.
Check that power is getting to the gauge lights with a voltmeter.
Ron
Old May 6, 2002 | 08:07 AM
Vader's Avatar
You may have also damamged the dimmer control module, located below the radio in the dash.
Old May 6, 2002 | 11:46 AM
gruveb's Avatar
Car: 1989 IROC-1
Dimmer module under the radio? Maybe that's my problem. Mine haven't worked for a very, very long time.
How do I check it and what does it look like?
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
Vintageracer
Jan 10, 2020 05:33 PM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
Omega
Aug 10, 2015 12:46 PM
