Question on installing new door latch
Old May 8, 2002 | 05:52 AM
Steve's Avatar
Car: 91 Z28
I was going to attempt an install of a new door latch on the drivers door. This is the part that goes over the stircker bolt ( think that is what you call it ) when you close the door. Is there anything i should be concerned about when doing this or is the change straight forward? Any tips on this would be appreciated.
Thanks,
Steve
Old May 8, 2002 | 11:15 AM
Vader's Avatar
Steve,
Yes, that is what it is called (striker). There is no "magic" to installing a new latch mechanism, but there are a few tips:
1. Use caution when removing the interior door trim so you don't damage the fiberboard liner behind the upholstery. A special trim removal tool can be useful in popping the push fasteners loose without scratching the door paint and breaking the fiberboard liner;
2. Plan on replacing a few of the trim fasteners, since they won't hold as well once they are pulled from the holes;
3. Have some duct tape on hand to reattach the interior fish paper splash shield behind the trim panel;
4. Get some white lithium grease (like Lubriplate 107) to relube the linkages and window channels once they are exposed - you might as well while the door is disassembled;
5. Get some Loctite 242 or equivalent small screw threadlocker to coat the latch mounting bolts so they don't work free from vibration;
6. Set aside about two good hours for the job.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
BlackTopKing
Aug 19, 2015 12:13 PM
redmaroz
Aug 16, 2015 11:40 PM
BrianI
Aug 9, 2015 11:52 AM
