electric water pumps.
Old May 14, 2002 | 01:48 PM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Is anyone running a electric water pump on a daily driver?
What kind is it? and is there and benefit changing to the electric version?
thanks.
Old May 14, 2002 | 05:44 PM
ede's Avatar
ede
not sure any eletric pumps are made for the street. i have a moroso on my car besides an expensive pump you need a 150 dollar pulley for the crank to drive the alternator.
Old May 14, 2002 | 06:19 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
i always thought elec. water pumps were strictly race only
Old May 14, 2002 | 06:45 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Same here.
Old May 14, 2002 | 08:07 PM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
You're better off asking this on the camaroz28.com board. A bunch of folks run Meziere or CSI electric water pumps on their daily driven LT1s with much success. FWIW, both companies claim over 35 gpm flow and a 2500 hour motor life expectancy and can be run on the street with no problems.
From what I've been reading, I'd have no doubts it would cool just fine but reliability is my main concern. I'm thinking about running one myself but I'm still trying to get an idea of how reliable they really are before I do it.
Old May 14, 2002 | 09:18 PM
breathment's Avatar
i remember seeing some streetable ones in Summit cataloge.
Old May 15, 2002 | 07:38 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
yeah I am a little weary about, if electric pumps would hold up on the street.
Is there any power gain in going to a electric pump? I dont think it is worth it on a mild street/strip car.
thanks for the input. I here they work good on the LT1 but I had not heard anything about a 350 TPI motor.
thanks
Old May 15, 2002 | 10:28 AM
gruveb's Avatar
Car: 1989 IROC-1
The only purpose I could see for using one would be if you lived somewhere HOT and wanted to circulate coolant for a few minutes after the car was shut off. WIth an electric fan and electric water pump you could cool down pretty effeciently!
Old May 15, 2002 | 11:59 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
The http://www.meziere.com (said Mez-ear, not mez-e-air-e, like I used to think) site has more info. I sent a few emails back and forth to Don a couple years ago; interested in using the remote water pump for my 2.8 v6. (It's not similar to your v8 pumps, the whole back of the v6 pump is the gasket/sealing area!) Anyway, Don said that their pumps are extremely durable for the street, and they even offer rebuild kits for 'em.
Ah, here's the email, from March of '99 - I should clean out my email folders, eh? Here's a quote from Don Meziere:
> > Tom,
> > Our water pumps have been used quite succesfully on the street. In
> > fact, the pump that was on the PHR cover in Dec '97 went in a street
> > driven Nova and is among the most reliable parts on the car. The
> > life expectancy is around 2400 hours. If you average 15 MPH thats
> > the equivalent of 36,000 miles! To test them we have a stand that
> > cycles the water between 190 and 220 degrees F. The pump that is on
> > the stand now has been running 24 hours a day, 7 days a week since
> > November 12th.
> > Please let me know if you would like any additional information.
> > Sincerely,
> > Don Meziere
Old May 15, 2002 | 12:01 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Oh, and that November 12th he mentions... it was probably November 12th of '98, since that email was dated March 4, 1999.
Old May 16, 2002 | 09:35 AM
Vader's Avatar
The advantage of an electric pump is that you can install an SCR control and vary the speed of the pump based on engine heat, not engine RPM. You can cool the heads down quite a bit just before a run by manually cranking up the pump speed.
As for power gains or losses for a daily driver, all you're doing is transferring the load from the crankshaft directly to the alternator, which only introduced some more inefficiency. The advantage is for those short, peak-power runs you have an extra ½ HP at the cranks since the battery takes the load briefly. If that ½ HP is worth the cost and installation hassle, go for it.
Old May 16, 2002 | 09:39 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
thanks vader.
That was the answer I was looking for. My friend has a 70 nova, and was suggesting that I swich to a electric water pump. His car is strickly race, it hauled to the track. I dont think it is worth the time or the money for such little gain on a street/strip car.
I was just needing proof.
Thanks again.
Old May 22, 2002 | 09:38 AM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Electric water pumps are not just for the strip anymore. Everyone talks about the Meziere 35gpm pump which works AWESOME in LT1 street vehicles. Well, Meziere also makes a 55gpm electric pump with a heavy duty motor. Yea, thats right ... 55gpm. I just bought one ...
http://www.xecu.net/timsiford/pump/
Tim
Old May 22, 2002 | 10:06 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Tim
What advantages do you think you will get with it? Do you have it installed?
Old Nov 9, 2002 | 01:29 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
Any helpful info you could share TRAXION? Did i see a pic of when you had a CSI pump? If so, how difficult was it to mount the accessory brackets? I also saw brackets that look custom on your set up! Are they? I am having trouble mounting things now without the stock pump and using the CSI pump. Any ideas or suggestions, from anyone? Thanks for your time-Bryan
Old Nov 9, 2002 | 01:55 PM
TRAXION's Avatar
Bryan,
I do have a suggestion but you are NOT going to like it. Meziere now offers a BOLT-IN electric water pump for serpentine TPI applications. It comes with an idler pulley so that you can route your belt around it just like stock. It's an awesome idea. But, be prepared to pay for this setup .... it's like $425!!
I have this same pump but WITHOUT the idler pulley. I have a fully custom setup so I really can't be of help too much. However - you could always just reroute your serpentine belt? Crank to PS to Alt to tensioner to AC to smog to crank. I haven't tried that routing but it might work ... just depends if the belt has enough footprint on the crank pulley.
Tim
Old Nov 9, 2002 | 03:19 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
Thanks a lot, You da man! Seriously though, i came across another old post and found that pump. I believe someone with a Trans Am has it, forgot his name. I believe the part # is WP3215 if i wrote it down correctly. I will have to call them on Monday and see what they have to say. Yeah, i figured your brackets were custom, really have not seen any like that around! I just looked on your picture directory and figured they were custom. On your site i don't recall you naming them. Anyways, thanks for your help. I am probally going to need some more info on other things but i'll just PM you i guess, if you have the time though, no big deal. It just looks like you have a lot more experience with this setup than most who are willing to share the info. Thanks a lot for your time again. Later-Bryan
Old Nov 9, 2002 | 05:31 PM
89BlueTA's Avatar
I think you would gain quite a bit of power from an electric water pump, since you could turn it off while you raced. So you would have no draw on the alternator. I think I am just going to ditch the serpentine system and just run the crank, alt and powersteering.
nick
Old Nov 9, 2002 | 05:57 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
That was my intention, not nec. for "more" power" though. I was planning on running a relay for the pump and the fan in my car. This way in the staging lanes i could always turn them on to cool off and shut them down for the track. Not so much for the pump but definately for the fan! The car is not even a daily driver, just my toy/money pit/baby. What my real concern is though, using the CSI pump, you can not mount the accessory brackets anywhere! As far as i can tell anyway. This was my question. How to properly hook it up and my accessories too? I will have to either go with that Meziere pump or go with a regular old aluminum pump, either Stewarts or Edelbrocks. We'll see, but i doubt i'll get this pump to work with my current set up, unless someone has any other ideas. Thanks edit: oh yeah, there was someone who posted dyno results with an electric pump. It was in an old post i found on this topic. I believe it was 11hp. Not bad but every bit counts!
sheachopper
Jul 31, 2019 11:27 AM
SRKLEGIN
Oct 29, 2015 06:38 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
lanceflame44
Sep 25, 2015 12:28 PM
