ticking? not lifters correct?
Old May 18, 2002 | 08:26 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
i have a ticking sound thats under the hood when i bring the rpms up, doesnt tick at idle or low rpms lifters are new with 1200 miles on them, lifters would tick all the time if improperly adjusted right? would a header collector sound like that?
Old May 18, 2002 | 09:49 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I'd check for an exhaust leak around the y-pipe area.
Old May 18, 2002 | 12:55 PM
ede's Avatar
ede
i'll second the exhaust leak
Old May 18, 2002 | 03:43 PM
rhuarc30's Avatar
They're probably right about the exhaust leak, but if that's not it check the injectors, they can tick pretty loudly sometimes.
Old May 18, 2002 | 03:47 PM
Car: 99 Formula
Axle/Gears: 342
I was thinking the same, but he has a carb.
Old May 19, 2002 | 11:14 AM
Vader's Avatar
Did this noise start shortly after the cam installation? A lot of dual-pattern cam profiles can induce valve train noise. I've had this happen more than once on roller cams with heavy ramps. The noise seems to be more prevalent at idle and low RPMs, and fades away at about 1,400-1,700 RPM.
Old May 19, 2002 | 11:34 AM
BuddyLeeX's Avatar
Car: 06 Toyota Tundra SR5
yeah either exhaust leak and/or what vader said. But I would check the rocker arms also, we were tuning my friends t/a and a couple of his rocker arms werent tightened right and was making a clicking noise.
Old May 19, 2002 | 02:12 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
well i adjusted all rockers, your right about the increased valve train noise, but at idle with the valve covers on you dont hear a tick, i do hear some exhaust noise/leaks at idle, so maybe thats it as i only here ticking at medium to high rpms
Old May 19, 2002 | 05:15 PM
craig's Avatar
Car: 86 camaro
Engine: 433 big block
Transmission: jw powerglide 5500 coan stall
Axle/Gears: moser9" 4:11 posi
ticking noise with a dual pattern cam? i've noticed that with my new cam. ever find out why they sound like that?
Old May 19, 2002 | 07:56 PM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
Hmm, mine does the same exact thing. I put an LPE 219 cam almost 2 months ago and it does have an agressive ramp, although it's a single pattern cam. I adjusted the valves with the motor running and have replaced the header and collector gaskets. I put in Comp Cams roller lifters, pushrods, and springs when I changed cams. The springs were properly shimmed and it couldn't be the lifters cuz they're brand new. After 1500 rpms the ticking goes away.
So Vader, are you saying this is normal??
david068513
LSX and LTX Parts
Nov 15, 2015 11:37 PM
corey8084
Sep 17, 2015 02:56 PM
david068513
Sep 13, 2015 11:24 AM
david068513
South East Region
Stryker412
Sep 7, 2015 09:11 AM
